TwinTurbo.NET: Nissan 300ZX forum - Your fuel pressure should be 43.5, at zero manifold
octavian-z
on April 13, 2007 at 2:04 PM
My Z is sick.
posted by Zenica
on April 13, 2007 at 01:53 PM
pressure, and should increase 1 psi for every 1psi of boost. How much boost are you running? It may be your fuel pump, or the fuel controller
My Z is sick.
Zenica
13:53:55 04/13/07
50 psi is a bit low for full throttle
spyhunterTT(nj)
13:59:16 04/13/07
Re: 50 psi is a bit low for full throttle
Zenica
14:02:41 04/13/07
it is very easy, its on top of the plenum. like 2 10mm bolts
NobleZ
14:06:27 04/13/07
Your fuel pressure should be 43.5, at zero manifold -
octavian-z
14:04:21 04/13/07
I forgot, also check your FPR (n/m)
octavian-z
14:06:34 04/13/07
correct, but will dip below that at idle, since
Guapo
14:09:28 04/13/07
Thanks for the replies..
Zenica
14:12:47 04/13/07
RE: Idle psi
Broke_as_****
14:19:24 04/13/07
It's an erratic jump because the fuel pump controller
octavian-z
14:26:21 04/13/07
With your mods, you should be around 375 rwhp.
eriksu9
14:25:04 04/13/07
Re: With your mods, you should be around 375 rwhp.
Zenica
14:32:47 04/13/07
that doesn't sound too far off
spyhunterTT(nj)
14:38:33 04/13/07
Re: that doesn't sound too far off
Zenica
14:41:48 04/13/07
A vacuum leak would cause him to run rich, not lean. (n/m)
Billteed1
15:00:52 04/13/07
I should have said a boost leak.
Billteed1
15:27:16 04/13/07
I would check for a vacuum leak after checking the FPR
olyar15
14:29:29 04/13/07
How would they let in unmetered air
Billteed1
15:02:38 04/13/07
Not on the inlet side
Broke_as_****
15:07:42 04/13/07
Re: Not on the inlet side
Zenica
15:17:04 04/13/07
Carb sprary is good for find a leak...
Broke_as_****
15:51:36 04/13/07
Re: Carb sprary is good for find a leak...
Zenica
16:00:27 04/13/07
I see
Billteed1
15:25:28 04/13/07
